Add on
02-21-2018 01:48 PM - edited 01-04-2022 03:34 PM
03-03-2018 10:46 AM
I did not purchase it twice one of the moderaters Shaza( not sure of the spellig) fiixed it for me
02-21-2018 02:37 PM - edited 02-21-2018 02:44 PM
@imm1304, yes it works (confirmed with my dad in the US).
When I forgot to renew the US roaming add-on a couple of weeks ago, there was no indication anywhere there was a US roaming add-on (which was correct).
So it looks like as long as it shows up somewhere (and not necessarily in the "Overview" tab), the add-on works.
Which is really weird because it was appearing in the proper places at the proper times a month ago...
02-21-2018 02:34 PM
Hey @bumpark,
Can you confirm that the actual roaming service works but its a display issue on the Overview page?
02-21-2018 02:30 PM
I have the same problem - everything indicates the US roaming add-on was purchased and active, except on the Overview tab.
Here are the details I sent to a mod (who hasn't provided a legitimate reason except for, "it should be there...oh well"):
I understand the two-step process and have previously added on the US roaming packages.
I pay for my dad's phone who is snowbirding right now so am constantly topping up his US add-ons.
Recently there have been some issues:
In "Overview" tab, the US roaming add-ons don't appear in "My Data & Add-Ons" section; they did previously.
So it looks as if there are no US roaming add-ons.
But when I click on "Purchase Add-ons", the US roaming add-ons appear as "Current-Add ons".
In the "Plan and Add-ons" tab, the US roaming add-ons also appear.
In the "Data & Add-on Usage" tab, none of the US roaming add-ons appear.
I used to be able to view usage and would top up with a US data only add-on, if it got close to the 250 data limit.
But usage no longer appears.
To sum up, I am getting conflicting (or no) information on US roaming add-ons in Self Serve.
02-21-2018 02:04 PM
Hey @carriecameronbc,
Please send a private message to @CS_Agent and provide your public mobile phone number so that one of the mods can fix the US add-on purchase for you.
02-21-2018 02:04 PM
@carriecameronbcwrote:No my balance is 0. But it shows up in my transactions as being purchased.
Go to your plan detail page and you might see the added add-on there.
02-21-2018 02:01 PM
02-21-2018 01:55 PM
@carriecameronbc Did you purchase it twice? If not, see if the funds you added are added on your Available Balance. If yes, purchase the same add-on again and this time it will add to your account.
