08-02-2019 09:25 AM - edited 01-05-2022 08:28 AM
Add a add on but not showing up. Where can i see if. It active. Have the $ 15 plan 100 talk. Add a Extra $ 5. 500 min talk.
08-02-2019 09:49 AM
Thanks for your help 👍 5 stars for you
08-02-2019 09:47 AM
Thanks for the help 👍 5 stars for you
08-02-2019 09:45 AM
the reason you see the balance $5 is because you upload the money but not purchased the add on. So go ahead to select the add on you want, then you will see the add on.
08-02-2019 09:42 AM - edited 08-02-2019 09:44 AM
Ok that's good, first step is done
Use that balance to purchase the add-on
Go to the add-ons ad choose the one you need
08-02-2019 09:41 AM
Its saying i have a balance of $ 5
But under my add ons i dont see it
08-02-2019 09:40 AM
@Salvo wrote:Its saying i have a balance or $ 5.
But under my add ons. Its not showing up ..
Right. So that means you still need to do the second step. Go back in and use that $5 to actually buy the add-on.
08-02-2019 09:40 AM
Purchasing add-ons is a two step process.
To purchase Add-Ons using your Self-Serve account, follow these steps:
08-02-2019 09:39 AM
08-02-2019 09:26 AM
@Salvo wrote:Add a add on but not showing up. Where can i see if. It active. Have the $ 15 plan 100 talk. Add a Extra $ 5. 500 min talk.
Did you do the second step? You need to deposit money and then buy the add-on. When successful, you'll see it in your Data & Add-ons area.
08-02-2019 09:26 AM - edited 08-02-2019 09:27 AM
It's 2 step process
Did you complete both steps?
Can you check your payment history and see what is going on?
