Add data
chrismuller
Hi I would like to add more data to my plan  I need more data thank you
CS_Agent
Customer Support Agent
Hi Chrismuller !
Thank you for reaching us!  As will13am says you can add data on your self-serve
If you need any help feel free ton contact us by private message to the Moredador Team  ! 😉
Cheers,
Celsina
will13am
@chrismuller, I have edited your phone number.  Please do not post personal information on the public forum.
With respect to you issue, there are two ways to get more data, buying on expiring add-on data as already suggested.  The other option is to early renew your existing plan.  Option 1 you do yourself.  Option 2 will need to be done by the moderator team.  Weigh the options and decide which works best for you before proceeding.
LEGO
PLEASE, REMOVE YOUR PHONE NUMBER!
You may purchase Data add-on through your Sel-Serve account.
Purchasing Add-ons is a TWO step process. Once you add the funds, then you need to make the actual purchase. Detailed instruction: click here
