Add data
01-10-2018 12:27 PM - edited 01-04-2022 03:17 PM
Hi,
I have a 3-month plan and my data is over, I was trying to add on some data as i am travelling tomorrow. I could not find any option on self-serve can some please suggest or guide me on how to do it.
My Account
01-10-2018 12:38 PM
Add-on data is quite expensive. As suggested, the most cost effective solution is to ask the moderator team to perform an off schedule account renewal.
01-10-2018 12:31 PM
Hi @mohammednadeem5,
Alternatively, you can send a message to the Moderators and request to have your plan renewed early if you are close to your renewal date or if that works out to be better for your situation.
To send the Moderators a message, use the below link (be sure to include your account details such as phone number, account number, pin and your request):
01-10-2018 12:29 PM - edited 01-10-2018 12:30 PM
You first need to add the necessary funds to your account balance. $10 for 200MB or $30 for 1GB. It will never expire.
Then, go into selfserve, click "plan and add-ons", then "my add-ons". You will see the different add-on options. Select the one you want and purchase.
