Add Ons
Lolivero
Can't buy Add Ons since yesterday! Why? Thanks
imm1304
Hi @mike_mccorms!
Unfortunately, there is no other choice but to wait for the mods.  Hopefully you will hear back from them soon.
Hang in there.
Acekiller
bugs after bugs...
mike_mccorms
@imm1304 @Lolivero @ShawnC13
To further clarify previous message: I show $10.00 "Available Funds" and have now twice attempted to purchase the Canada 200MB data add-on, but it is not showing on my account. Hopefully someone can help? Thanks!
mike_mccorms
@imm1304 @Lolivero
I posted the same issue in a thread earlier this morning. I followed the steps as outlined by @imm1304 in this post, and am still experiencing the same issue.
https://productioncommunity.publicmobile.ca/t5/Discussions/Attempting-to-purchase-data-add-on-not-wo...
I also PM'd the moderators but have yet to hear a response.
ShawnC13
@Lolivero, this seems to be an ongoing issue for the last couple of days and it seems the only fix is to message at Mod as @imm1304  has suggested and they can add the addon to your account.(As long as you have the amount required for the addon in available funds)
imm1304
Hi @Lolivero!
The add-on system is programmed to deduct from the "Available funds" you have topped up.
So, if there were no funds in your account, then you are directed to top up first. Once topped up, you should go to the buy add-ons page and complete the transaction.
If my suggestion is not helpful, the only way forward is to send a private message to @CS_Agent.  Provide them with your phone number and tell them which add-on you want.  One of the mods will be able to help you with this.
