Activation
Harry23
Good Neighbour / Bon Voisin
I've tried everything but it still saying "Subscription Not Activated". I also cannot send a support ticket as the submit button is greyed out..can someone help me please
I tried resetting my phone and everything
1 REPLY 1
slusagm
you tried reboot phone and login the app agian?
or if that does not help, you will need PM to fix.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
