Activation getting error code
Shane46
 i am getting this error when trying to set up a new account
Shane46
This isn't opening anything is there a person I can talk to not just chats this is very frustrating not physically speaking to someone
Shane46
I don't have any those options yet it won't let me past the step of entering my payment information
slusagm
are you activating physical or esim?
if physical sim, you can put in the PM sim card and test if you can make calls.  But if you are activating eSIM, check the Sim Manager or Settings->Cellular and check if the PM esim is there and enabled.  Then Reset network settings and test
if you need PM to help, open a ticket.  Since you cannot login and cannot use Chatbot,  you will need to send PM  a message
