01-26-2026 04:25 PM
I set up a new account yesterday and it still does not work. I get cellular network is not available for calls and no internet for data
01-27-2026 04:08 PM
I think I have found the problem. I did not send a "Yes" reply to the TELUS text confirming my request. Can you send another request to TELUS to transfer my cell service so that I can get this working?
01-26-2026 05:02 PM
Hi,
"Remember CS_agent will reply to your Community inbox within 2 to 4 hours, .."
We appreciate your help very much but please manage the expectation for us since currently it is impossible to get reply within 2-4 hours. Without PM saying a clear root cause and ETA to subscribers, will drive us crazy.
01-26-2026 04:27 PM
hi @Blake4
eSIM or physical sim? if physical , try on another phone
if eSIM, make sure old sim cards are removed, old eSIM is disabled. And then set PM esim to Primary and enable it. Try Reboot phone and Reset netowrk Settings.
if same, ask PM support agent to help, you can submit ticket by direct message:
