11-17-2016 08:08 PM - edited 01-05-2022 12:33 AM
I activated my PM SIM 3 hours ago, service still hasnt connected. However, my Telus SIM is no longer being reckognized.
Please advise how much longer for this procedure to complete, I see this as a recurring issue with new users.
Hope this is sorted asap
Thank You,
M
11-18-2016 03:03 PM
@Shazia_K problem solved! Thank you, a representative from PM also called to confirm if my phone is working.
There was a minor issue with the porting, Shazia sent a ticket to IT. The problem was resolved within an hour after Shazia dealt with my case.
Thank You! Service is workign very well so far.
M
11-17-2016 09:26 PM
Thank you I will continue to restart my phone. Hopefully, it works soon.
11-17-2016 09:25 PM
I do not have a self service account- only a community discussion account.
Registering for one requires a 6 digit activation that's sent to my phone(but I don't have service)
11-17-2016 09:15 PM - edited 11-17-2016 09:20 PM
11-17-2016 09:11 PM
How do I access this info?
11-17-2016 09:03 PM
Can you login to self serve
do you see your new number under plan settings?
11-17-2016 09:00 PM
somebody restarted 4-5 times and somehow it worked.. other than restarting i dont know, sorry!
11-17-2016 08:18 PM
11-17-2016 08:12 PM
Try restarting your phone. This helped me and others
11-17-2016 08:12 PM
Yes I ported my number but used a different e-mail
11-17-2016 08:10 PM
Did you ported in your number while activating? Did you use the same email you used on Telus account?
