Activating new SIM card form problems
hazzelnut
I'm trying to activate a new SIM card, but when I reach step 2, the dropdown for city/region doesn't work when I click it. I've tried it with Chrome and Safari and the same problem persists. Any help?
hazzelnut
Okay, I ended up disabling all my extensions while in Chrome Incognito and that worked! Thanks
hazzelnut
@krazykiwi  I just re-tried with incognito in Chrome, and still get the same result. Unable to get past step 2. The dropdown for selecting city/region still comes out empty.
@hazzelnut wrote:
@Anonymous Okay, I'll try that but in the meantime I'll have to wait another 50min because I tried activating previously on Safari. This will be my third attempt ... 😞
This is exactly what I was talking about. Close all your windows, clean your cache. Try to get rid of all traces of your previous attemps, then try as @Anonymous suggested.
hazzelnut
@hazzelnut
Sometimes just waiting a little while and then trying again works as well.
@hazzelnut, I suggest you retry with chrome (again), but this time use Incognity(privacy) mode.  This type of problem is often resolved by using the privacy mode of the browser.
