11-11-2022
07:09 PM
11-11-2022
07:15 PM
computergeek541
I am new to public
i was given Error code 837
and a message said to change my region from ON
i am in BC and have no idea what this means
11-11-2022 07:52 PM
@KirstenMusial , the province information is not important. This service does not discriminate in any way based on region. If you cannot change the province, don't worry about it.
11-11-2022 07:10 PM - edited 11-11-2022 07:11 PM
@KirstenMusial Go to the PM home site: https://www.publicmobile.ca/en/on/ and change the region located right below the Public Mobile logo. Also, try activating using Incognito/Private browsing mode.
EDIT: You can also use this direct link for BC Region: https://www.publicmobile.ca/en/bc/
