Activating SIM card error 821
PhilGpm7995
Activation error 821
2 REPLIES 2
PhilGpm7995
It has been fixed.
Thank you so much.
HALIMACS
@PhilGpm7995
This usually means you used the IMEI instead of the account number when porting.
Check to see if your payment card was charged before trying again.   If it wasn't, try the account number from the old provider the 2nd time around.
If you require CSA support, here's how to reach them:
  1. Use the ticketing system for a faster response time. Click here and type uCustomer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
