09-22-2018 10:09 AM - edited 01-05-2022 01:53 AM
09-23-2018 08:57 AM
check your online account, if account online looks normal, just maybe need reset your phone setting,to check carrier choose auto
09-22-2018 08:46 PM
You can try to take out and re-insert SIM card and then re-boot your phone. If you tried the network reset already, possible factory reset.
If that does not work, you likely will need to contact moderator for further help. Expect 1-2 day wait. You can send a private message through the following link :
Please include in the private message your phone number, your account number and PIN code.
09-22-2018 01:18 PM
Yes, phone is unlocked
09-22-2018 11:35 AM
@Vladimir wrote:No. But it shows antenna
Is your phone unlocked? Try using the network reset.
09-22-2018 10:39 AM
09-22-2018 10:38 AM
Activation was home.
I got a new number
Model is Samsung S7
I took the plan $10 for my son(just have calls)
It says mobile networks not available
09-22-2018 10:24 AM
What does self serve say about your account?
Does public mobile show up when you do a network search?
09-22-2018 10:22 AM
Sorry to hear about your troubles. Can you provide more details? To help determine if the community members can help or you may need help from moderators. Where was the activation? home or instore? Did you get a new number or port a number from another provider? Which model phone? Able to call in/out, text in/out, data? Does your phone show pubic mobile network?
