Activate Website Says SIM Number Invalid
moxuz
Hi, I am on the activation website but the site says my sim number is invalid. I bought this SIM card from amazon. Am I doing something wrong? I have entered then umber multiple times.
Chris
moxuz
It worked in incognito, thank you!
@moxuz     like @iliketotalk  said try incognito mode.  Also they say you it helps by clearing your cache first!   Good luck
iliketotalk
moxuzz  hi you may have to wait an hour if you tried to many times then reboot your computer and use chrome in ingognito mode
