Accounts
boborchison
I was not initially aware that I needed different login passwords for my self serve Account and Community account. Did anyone else have this issue?
geopublic
@boborchison  Passwords could be anything you chose and can be the same. Did you mean usernames cannot be the same?
I am fairly certain my passwords are both the same. But my Self Serve account uses my email address as my account name while the community needs a screen name to log in, so they are different.
AE_Collector
popping
@boborchison
Correct, you need different login for the support forum.  They are loosely linked by using the same email address.
ChuckYeah
I was not aware of that either. However, it is safer to have diff. pwds for all your accounts.
Just out of curiousity, where did you obtain this info?
