2 hours ago
By login into my account today I noticed outgoing calls from my phone and the numbers that I never used
the number is 1 (778)580-4001 and it’s been used quite a few times could you please check what’s going on
thank you
2 hours ago
those. numbers end with 4001 are voicemails
PM will show you the usage history when you check VM or when someone leave VM
2 hours ago
that's voicemail number.
2 hours ago
4001 is a voice mail number
2 hours ago
That is the voicemail phone number that you use to check your voicemail that's normal to see
