07-25-2022 09:09 AM
I logged in to change my credit card expiry as it’s expiring at end of July and my account has been suspended, not allowing me access to make the necessary change. Now, I’m locked out from trying to log in too many times (and I even changed my password). Next steps would be?
Payment
07-26-2022 02:20 AM - edited 07-26-2022 02:23 AM
@Yummy wrote:If you are locked out from your account due to too many attempts to log in, try in few hours. If it does not work even then, contact agent to unlock your account.
This is no longer the case. There is no longer any specific amount of time for lockout. The customer will need to start a new browser session to try again.
07-25-2022 09:24 AM
07-25-2022 09:12 AM - edited 07-25-2022 09:15 AM
@Mattincd hi it takes three hours to reset if you still are having issues
hi you will need to open a ticket through Simon to speak to a customer service agent they will help you mention reset email for self serve account
Click here if you have issues using Simon , try to pm them here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 you will get a response from them in your community envelope , they can also help you update your credit card info
07-25-2022 09:11 AM - edited 07-25-2022 09:12 AM
if it is just a lock, you can either wait 3 hours for the account to unlock itself
But since you have changed password earlier and didn't work, you should open ticket with Pm Support and have them to sort it out for you:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
