06-27-2022 02:01 PM
How do I reset my account pin as in the four digit number used to call 611 while we’re out it how do I change my account email since it seems to be the only thing it doesn’t show up in my profile.
thank you
06-27-2022 02:04 PM
@scottsault you might got a text or email form the very beginning when you first setup PM service, that might have your PIN
But if you need to reset PIN, only PM support can help:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Reset PIN", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-27-2022 02:04 PM - edited 06-27-2022 02:05 PM
@scottsault 4 digit account PIN can only be reset with CSA. edit, same with the email connected to your self serve..only CSA can change it.
Contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
