Account is made but phone number still needs to be transferred
Cheryl1952
I activated through Public Mobile with a sim card and requested the transfer of my phone number. The SMS request to transfer came through, I said "Yes". I changed the sim card to Public Mobile before the phone number got transferred. Now I have the Public Mobile account activated, without being able to change the phone number to my current number. I put the old sim card back in from Bell. It still works. How do I transfer the phone number now when the account is activated? What do I do?
@Cheryl1952  -
Cell ports take 2-3 hours to complete.
Landline ports take 3+ days to complete.
Which did you do, and when did you activate?
If you are over this time period that is when you contact Public Mobile or call the Porting Phone number.
Things to do to trigger the network while you wait for the port to complete:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
 @Cheryl1952 : I don't think you need to talk to anybody yet. Just let it finish. When the Bell service stops then you'll know. You might even get a text saying to insert PM SIM. Then turn off the phone, insert the PM SIM and restart.
0PX9O4
@Cheryl1952
I would recommend you contact PM instead of sending in another porting request. You already did send it through before, and if something isn't quite right, self serve will not fix it for you.
HALIMACS
@Cheryl1952
You can prompt the phone number port through your self-serve account if you were assigned a different number upon the activation.
Click on the Change Number option.
You might also wish to try  https://chat.telus.com/chat/publicmobile/chat-pm.html?portal=publicmobile&language=en
0PX9O4
@Cheryl1952
I am sending you a private message with a number to call. Look out for it on the top right corner (the envelope icon).
