Account disabled
samtse
Cannot login as the account was disabled.   Thanks.
Jackhyf63
Your account will be suspended if payment is not received on your rate plan renewal date, and will expire/deactivate on the 90th day. That also means that on the 90th day you would lose your telephone number associated with your rate plan and your self-serve account will be disabled.Your old SIM card will not work either and you will have to create a new account.
Alex888
@samtse Are you a returning customer or did you forget the password?
hairbag1
How long has it been disabled ? If over 90 days, then account is closed for good. You'd need to get a new sim and start over.
