Accessing app
MyrnaMotoGPower
Get stuck logging in as security code is being sent to a number I no longer have. Tried help and just get stuck on a loop where it results in being asked to login, which I obviously can't do. Frustrated and ready to go somewhere else
2 REPLIES 2
slusagm
Supposed you can get code via voicemail, but if number is wrong, that won't be a valid option
Get the code via email.  Click Didn't receive code and select Send email
If bi such choice, then ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Chalupa_Batman
Click on "Didn't get code" and you SHOULD have two options. Send to email or voicemail.
If those options aren't available, reach out to customer service.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
When you're able to log into your account, go here and correct the number.
https://eversafe.id.telus.com/user/selfservemenu
