11-11-2017 01:07 PM - edited 01-05-2022 03:34 AM
I am unable to access "my account
I registered several years ago and I do not have the same email address. When I try to re-register it states that I am already registered, but I cannot reset my password to gain access as it does not recognise my new email address....
11-11-2017 01:25 PM
Hi @HelenHancey!
Best to just send a privte message to the mods as suggested above by @NDesai. Provide the mods with your public mobile phone number so they can find your account. The mods will take care of this for you.
11-11-2017 01:24 PM
Ah ok. Then sending a message to the mods as NDesai suggested is the way to go.
11-11-2017 01:21 PM
I still have a current active account. I have just not been in "My Account" online for several years
Helen
11-11-2017 01:17 PM
When was the last time you had an active plan on this account?
After 90 days of inactivity (no plan) your SIM card and account get deleted including all remaining credits in that account. Then there is no way of restoring the account.
11-11-2017 01:11 PM
You will have to send a private message to the Moderator_Team with your account info. If you are on a legacy or pioneer plans, you can call 611 for help.
