Accessibility outside Northern America
User18
I have a problem accessing the signals outside the North America.
Due to muti factor authentication I couldn’t access my mails and many other accounts associated with my mobile number.
Could you please suggest me a suitable solution for this problem.
13 REPLIES 13
@Timer wrote:
@User18
buy sim card local, in your place. and keep your PM SIM card save.
Edit: you can't access other account, tried use browser from computer, clear cache and cookies and use one page inPrivate mode, To Login Page
just by email, you can't login by mobile number.
you will get verification code by email
and when you press the 6 digit number and not press anything
just wait a 5 second automatically be login,,
Please stop spreading misinformation.  None of the above will help the customer receive 2FA codes by text message on the Public Mobile service to be able to access e-mail, bank accounts, etc.
@Timer wrote:
@User18
you can't do port out because you are out of the country canada.
This is incorrect.  The customer could port to another carrier, another Canadian carrier who can provide roaming services where this customer wishes to use it.  That may not help for now, but would for the next trip.
@Timer wrote:
@User18
you need to buy it add-ons, if you are in US for US roaming 10 day package.
The above is not relevant to this situation.  A U.S. romaing package will not help for places outside North America as User18 has asked about.
HI @User18
First, yes, PM does not have service outside of North America
If you need access to My Account, when they ask you where to send your 2FA security code, you have to pick email
If you are unable to access the email used to login, then you have to create another email address first, then open ticket with CS Agent and ask them to update the My Account login to your new email address
To open ticket :
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
@User18
If your SIM doesn’t work where you are then you will have to wait until you get back to Canada because you need to reply to the porting text confirming you are porting over to PM with your old SIM in the phone.
@User18
User18
Yes, it is a Canadian sim and it doesn’t work at my place
@User18
What is your current SIM a Canadian SIM and does it work where you are?
@User18
but if you have a wi-fi  Download the TextNow App
and make call and sms for free,
User18
Could please suggest me how I can port my number to a different service so that I can access my accounts to start off with my work
@User18
public mobile has just service for US roaming,
User18
Unfortunately am outside North America region.
Timer
@User18
