04-04-2019 07:00 PM - edited 01-05-2022 04:09 AM
When Publicmobile can have an app for the cellphone. We look forward!!!
Joining Public
04-05-2019 01:30 PM
@Neo2019 wrote:
@srlawren wrote:@Neo2019 if you're an Android user, I'd encourage you to have a look here: Appify Self-serve and/or Community sites
That's a great idea although I'm not an Android user, thanks a lot.
@Neo2019 nobody's perfect! 😉 Just teasing, and I'm glad you found the idea good regardless.
04-05-2019 12:34 AM
04-04-2019 08:48 PM
04-04-2019 07:46 PM
@Dunkgirl wrote:
@shskr wrote:I go to public mobile in browser on my phone, then I create a shortcut to my home screen. You can add user and password then create shortcut, but it will be logged in right away when you hit the shortcut. So anyone that takes your phone can log into your account. I just create a short cut to the self serve login page, then enter the user and password myself.
Hope that helps.
@shskrGreat idea. But hopefully the phone itself requires a password and locks when the screen turns off or after a short period.
@Dunkgirl yes it has a password and a finger scan (iphone 8+)
04-04-2019 07:42 PM - edited 04-04-2019 07:44 PM
Hope that helps.
04-04-2019 07:39 PM
Hope that helps.
04-04-2019 07:10 PM
With the reliability issues, not responding, server down, slow load times, glitches and bugs that we have with the activation portal, payment system and self-serve I wouldn't want them to waste their time making an app.
Give us better reliability in our existing system.
04-04-2019 07:03 PM - edited 04-04-2019 07:04 PM
@Neo2019 wrote:When Publicmobile can have an app for the cellphone. We look forward!!!
@Neo2019It would be great to have an app, but the website works good enough. I would take cheaper plans over an app anyday. Its very less likely to happen since even Koodo dropped the app in favour of the customers preferring the web interface.
