APN settings
Fred1334
What setting should be for APN
2 REPLIES 2
hi @Fred1334
I would try Reset Network settings first
If the Reset didn't help, then manually update the APN.  Have patience making the changes as this may require a little time of trial and error.
APN: SP.MB.COM
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type:   default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D4F
(***Any additional fields you don't see above, just leave them blank)
Here's a good starting point to check the APN settings:  https://www.publicmobile.ca/en/get-help/articles/set-up-data-on-an-android-phone
