APN question
AussieDoggo
Hi!
I have an iPhone 7 which I activated on the network today. When I inserted my SIM card, the APN "isp.mb.com" showed up. But SIMon suggested "sp.mb.com" and that's what I see on many websites. Does it change anything? Which one is correct?
Thanks 🙂
7 REPLIES 7
mimmo
data addons last as long as they are not used up.  my mom had used her data addon for a year.  you will only lose it if you account is unpaid for 90 days.
@AussieDoggo wrote:
Thanks everyone for your answers!
I have another question, haha! If I buy a data add-on but I have a 90 days plan, what happens to my remaining data, at the end of my billing cycle?
If you have plan data then it gets restarted. If you have add-on data then it stays around on your account available until you consume it.
AussieDoggo
@mimmo wrote:
Is your data working? If not use the setting found here
https://apn-canada.gishan.net/
Thanks a bunch! Nothing was loading with the default APN, for some mysterious reasons. But, with 'sp.mb.com', my data works A-1 😄
AussieDoggo
Luddite
@AussieDoggo wrote:
Hi!
Thanks 🙂
Either setting seems to be fine in iPhones.
anniemh2220
 @AussieDoggo
I'm just going to post this do that you can look up the different APN settings for different companies, Public Mobile included, and I'm pretty sure that it shows the APN settings for Android and iOS devices.
 https://apn-canada.gishan.net/en
Hope it helps.
Lmao oops forgot that link in my first post
mimmo
