APN for Jpro8
GT1
What is the APN for Jpro8?  My phone did not just automatically pick this up, and I may need to enter all the information manually.  Thanks, GT
Gregmt
Here’s how to set up data in 3 steps:
1) Tap: ➡ Settings ➡ More ➡ Access Point Names ➡ New APN Settings
2) Input this info: ➡ Name: Public Mobile ➡ APN: sp.mb.com ➡ MMSC proxy: 74.49.0.18 ➡ MMSC: http://aliasredirect.net/proxy/mb/mmsc
MMS port: 80 ➡ MCC: 302 ➡ MNC: 220
3) Leave all the other fields blank. Just hit save, and you’re good to go!
Also, make sure to enable data in your phone settings.
Here is to hoping this helps. Also I assumed that it was an Android phone.
Cheers .
srlawren
@GT1 what's a Jpro8?  I've never heard of that one.  Do you have a product page link?
Lieux
@GT1
NDesai
@GT1 You can find the correct APN settings here: https://apn-canada.gishan.net/en/apn/public-mobile
