911 issues?
10-29-2019 11:17 AM - edited 01-05-2022 09:35 AM
A couple weeks ago I tried calling 911 6 different times within a 20 minute period. Each time I got the automated message " All circuits busy, try again later" is that an issue with PM Service? Or.....?
Service
11-06-2019 10:06 PM - edited 11-07-2019 04:57 PM
Yes, sorry I should've mentioned that. The first topic in that link should explain everything.
Most people can think of RAN as a "tower".
11-06-2019 08:23 PM
@sheytoon wrote:No problem.
Leamington is Telus RAN territory. It's actually one of the boundaries between Bell and Telus RANs. East of Leamington is Bell RAN.
For anyone reading this and wondering what a RAN is, you may want to spend a few mins reading some of @sheytoon's awesome info from the past, in this awesome primer thread:
11-06-2019 07:56 PM - edited 11-06-2019 07:57 PM
No problem.
11-06-2019 12:29 PM
10-31-2019 09:14 PM - edited 10-31-2019 09:16 PM
@VDubbin that's a big problem. It's possible Telus is incorrectly routing your emergency call. If you are up for it, I would dial again from the same location and tell the PSAP you are testing 911 because it failed for the last few attempts.
If it still fails, try with another phone at the same location.
If it continues to fail, call Telus customer support and tell them 911 calls are failing consistently at that location.
May I ask what city you are in?
10-31-2019 09:09 PM
@Bogdan_S, what does that attachment have to do with multiple failed 911 calls?
10-31-2019 02:58 PM
You can also read more on the link below:
Bogdan_S
10-31-2019 02:56 PM
Hi @VDubbin,
I recommend you to go online and use SIMon and create a ticket so I can help you.
Bogdan_S
10-30-2019 02:30 PM
@VDubbin wrote:I was able to call anybody else without issue... and no it wasn't Election Day lol.
It looks to be an issue with local 911 services.
If it happens again, you should notify authorities, by dialing local operator (or an alternate emergency number).
10-30-2019 09:42 AM
10-29-2019 12:45 PM
Probably not much can be done about that but you would think that any 911 call would be accepted and they would have the capacity to do so.
10-29-2019 11:57 AM
@VDubbin wrote:A couple weeks ago I tried calling 911 6 different times within a 20 minute period. Each time I got the automated message " All circuits busy, try again later" is that an issue with PM Service? Or.....?
Nerwork issue. If it happens again, remove sim card to make csll. It might connect by Rogers or Freedom.
10-29-2019 11:43 AM - edited 10-29-2019 11:44 AM
That sounds like all the 911 lines (in your area) were busy.
Maybe too late to ask now, but were you able to call anyone else?
Btw, were you experiencing this issue on election day Oct 21?
https://www.google.com/search?q=election+day+911+calls&oq=election+day+911+calls
If so, you were not alone.
10-29-2019 11:29 AM
Never tried before, if that is the case, too bad..
10-29-2019 11:29 AM
@VDubbin usually that's an issue with the cell tower having no lines available but 911 is supposed to have priority and kick someone off to use that line! I would send a message to the Moderator_Team just to make them aware of the problem and they can look into it
10-29-2019 11:19 AM
That's a little disturbing.
