90 day plan
marknembhard
Can someone explain the 90 plan to me. I see an offer for $44 a month on a 90 day plan. I also stat with the 90 day plan you pay $39 and get 15GB plus 15 GB of data. Does that mean you get 30GB of data a month which is 90GB for the 90 day or it’s 30GB for the 90 day. Can someone explain. Please and thanks.
Grinch
On a 90 day plan you get ALL of the data to use and regulate yourself over the 90 day period.
@marknembhard
Yes, you will get a total of 30gb/month but it will reset on the next renewal date.
If you decide to pay for the 90 days or 4 payments/year…the $44 plan will cost you $39/month (30 days).
Proxima
yes it works out to 30gigs a month but you get a total of 90gigs for three months. This plan won me back from Virgin. I’ll be saving $16 plus tax per month.
The difference between the $44 plan. VS the three month plan- is that you save 5$ a month. every three months it will be $117 plus tax instead of 132$ plus tax
Plus, You get to keep the 90 gigs for the full three months instead of having the 30 gigs renew each month.
The 90 day plan is kind of like having rollover data- if you don’t use the full 30gigs each month it carries onto the next month until your renewal date. it is a better deal overall. I only use 8 to 12gigs of data month Max. but the extra does come in handy for inconveniences like power outages, WIFI outages, long transit rides.
