800 numbers
Jobone
I cannot dial 800 numbers. Everything else works.
2 REPLIES 2
hi @Jobone
this seems to be a common issue since 2 or 3 weeks ago.  Some , but not all, users cannot call 1800 numbers.  Only way to get it working is to ask PM support agent to help
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
you need to ask PM to refresh the account to get it working again
 Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
