lmchadwick1977
I dont know my password to 611 how do I reset it?
NM,  @Anonymous covered that.
Man, posting through mobile limits functions...err
 @lmchadwick1977 : If you keep all your texts like I do (I'm a low-volume user) then look back in all the texts from 611 and you might find your 4 digit PIN. It might even be stored on your SIM.
@lmchadwick1977
you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here link to get started.
  • or you can send a private message to Customer Service by CS_Agent, by Click Here link.
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,>> you will say forgetting and they will Reset for you,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck
JK8
@lmchadwick1977
You would need to contact a Customer Support Agent to reset your pin.
Your self service password can be reset in self service.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
