01-15-2018 05:51 PM - edited 01-04-2022 03:19 PM
Hi - I'm trying to make changes to my phone plan. Unable to make changes through selfserve online, message tells me to call *611. However, when I call *611, I get an error message saying I don't have long distance (which I do) and that I should call *611 to purchase an add-on, which I can not call.
Anyone encounter this problem before?
@CS_Agent, any advice?
01-16-2018 06:31 PM
Trying to move to a new PM plan from a legacy plan which self-serve does not allow you to do. It gives instructions to call 611 for assistance.
01-15-2018 05:59 PM
I think they are having issues with there service in general. The mods are slow to get back it seems, which may indicate wider spread issues. I am getting that same error that you are, but my plan just renewed today. Something is up...
01-15-2018 05:54 PM
Long distance is not needed to call 611.
What changes are you looking to make? Self-serve should allow you to purchase an add-on if that is what you are looking to do.
