08-27-2019 05:03 PM - edited 01-05-2022 06:41 AM
I have not yet received my 6 digit pin to finish registering
My Account
08-27-2019 06:14 PM
Thanks. I sent the team a message ( I think, hope). Just waiting for a reply. Again thanks for your advice
08-27-2019 06:11 PM - edited 08-27-2019 06:12 PM
@FrankD use this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
to contact the moderators.. they will get back to you in about 48 hours.
08-27-2019 05:57 PM
@FrankD the reply could take up to 48 hours but might be quicker! Click the envelope on the top right of the page and write to moderator_team and ask them for help with that
08-27-2019 05:53 PM
How do I do this. I thought I did but did not receive a reply. Thanks for your help
08-27-2019 05:52 PM
@FrankD sounds like you'll need to message the moderator_team to help you. I don't know why it wouldn't work if you can receive other text
08-27-2019 05:49 PM
I did recieve a welcome from public so I do have an account but it is not finished because I have yet to input a password to complete this
08-27-2019 05:46 PM
Hi, thanks. Yes I am receiving other texts and calls
08-27-2019 05:45 PM - edited 08-27-2019 05:45 PM
@FrankD so is your phone working? Can you receive text and calls?
08-27-2019 05:36 PM
I opened the link. It is the one I have been trying. I am still waiting for the code to be emailed
08-27-2019 05:14 PM
08-27-2019 05:10 PM
@FrankD does your phone work? Go back to public mobile.com and go on set up self serve account and you'll see where you put your cell number avd it will send you a new 6 digit code
