5g network?
1971bbhevelle
I recently switched to 5G, but my phone still says LTE?
1 REPLY 1
lilcold_141
Depending on the model of your phone, you may need to manually select 5G network.
If you are new to PM with eSIM and still have the physical SIM from your old provider, you may need to set the PM network as “Primary” otherwise it defaults to use whatever network of the old provider.
