08-06-2023 12:52 AM
Everything is working except the 5G. I Can make calls/texts. LTE is working as well. I have reset network settings.
08-06-2023 01:03 AM
I have done all.
08-06-2023 12:59 AM
where exactly you are at?
and you hve the 5G plan? sometimes you don't need 5G. On iPhone, you can set to 5G Auto and iPhone will decide when to connect to 5G and when to connect to 4G/LTE. If you are on a 5G plan, even you are connected to 4G network, you will have a speed higher than the capped speed of 100Mbps on a 4G speed plan
08-06-2023 12:56 AM
@Otter3 Are you around the city at all? Take a look at the coverage map to make sure 5G antennas are available near your area.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
