03-30-2026 08:33 PM
hi, apparently i already-subscribe , question is can i change subscription to the new 50% off ?
03-30-2026 08:50 PM
Thank you for your help,
03-30-2026 08:36 PM
If it shows up when you click on change subscription then yes if it doesn't then no
03-30-2026 08:36 PM - edited 03-30-2026 08:36 PM
Sorry @Tomytomta you cannot. The 50% plan is for nee subscribers only
You can port out the number and port it back in after for the deal
Other community members might say you can ask PM to help to get that , but they won't get you the 50% off plan, they will just give you some not so good options
