12-04-2018 01:44 PM - edited 01-05-2022 02:42 AM
I purchased the add-on 400 min Intl Long Distance (Incl Canada & US) yesterday morning so that I could make a call to the UK. But still when I try to make the call I'm getting the message saying that I don't have talk included in my plan and I need to buy the add-on. At first I thought it was just taking a while to kick in but it's been nearly 24 hours and I need to make this call ASAP.
Has anyone come across this issue? Is there an extra step I need to do to get it to kick in?
12-04-2018 02:08 PM
I have unlimited canada wide talk at the moment.
12-04-2018 02:06 PM
@srlawren wrote:Oh in fact it's probably how you're dialing. I believe it should be 01144, based on: https://www.timeanddate.com/worldclock/dialingcodes.html?p1=250&p2=136&number=0114+2329437
You beat me to it!! 🙂
Hopefully that solves the problem
GC
12-04-2018 02:04 PM
12-04-2018 02:03 PM - edited 12-04-2018 02:03 PM
@CliFlo it might be how you're dialing the number but I'm not sure about that--I'm sure someone will weigh in on that shortly.
In the meantime I wanted to ask one other question in case it's not the dialing pattern: does your regular plan include some talk in it? IE. you're on the $10/50/50 plan, or otherwise does your plan include at least unlimited province-wide talk? You need to have talk in your plan in order to use the long distance add-ons.
12-04-2018 01:56 PM
03444
12-04-2018 01:56 PM
I did the 2 steps alright. The add-on is showing up on my account. And says I have used 0 minutes of my 400. But just still won't call.
12-04-2018 01:50 PM
Here is an excellent illustration of the add-on purchase process.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
12-04-2018 01:48 PM
What are the first 5 digits that you are dialing?
12-04-2018 01:48 PM
@CliFlo wrote:I purchased the add-on 400 min Intl Long Distance (Incl Canada & US) yesterday morning so that I could make a call to the UK. But still when I try to make the call I'm getting the message saying that I don't have talk included in my plan and I need to buy the add-on. At first I thought it was just taking a while to kick in but it's been nearly 24 hours and I need to make this call ASAP.
It is active immediately. Now purchasing addons is a two step process the first time you "purchase" the addon the money actually goes to your available funds. You then need to go in and "re-purchase" the addon and it will take money from the available funds and add the addon to your account. So if you login to your self serve you will probably see $15 in your available funds. If you don't and in the addon section you see the addon listed there you could try the lost/stolen phone trick or you may need to contact the mods.
