2 hours ago
Does anyone know the fine print details of the $40/month plan?
I'm trying to determine if I should switch to the $39 CAN-US Plan
This is all it says for my current $40/month:
When I look at the details of the $39 CAN-US Plan it seems like the better deal as it also appears you can use your phone in the States without having to pay the additional roaming fees, please confirm if this is true too.
If anyone can advise, I'd be most grateful 🙂
Thanks!
26m ago
Ya it's a better deal you can use your phone in both Canada and the USA I just got the same plan for $39 myself too
2 hours ago
Thanks! Appreciate the confirmation of both issues.
Yes it seems to be like a lot of things PM is doing lately - still upset by how they gutted the rewards 😠
Thanks again for your help!!!
2 hours ago
Thanks! Appreciate the confirmation of $39 Can-Us Plan extra benefit.
2 hours ago
Yes the Canada/USA plan is a lot better. You can roaming in the US without purchasing roaming add-on.
Last month, the $39 Canada/USA was $34 with 50gb of data. Now the $34 Canada/USA is with 15gb of data.😭
2 hours ago - last edited 2 hours ago
Hey @JapanTrip
I had a Canada US plan a while back. Imagine, everything you do at home, making calls, texting and data, when you go to the US, it's the same thing. No difference and no extra charges. While in the US you can call and text to anyone in the US and even back to Canada. Use your data there too. I did a LOT of FaceTime while I was there. 🙂
