11-03-2019 05:26 PM - edited 01-05-2022 07:51 AM
Hi. I wanted to buy a Smart Watch that has a sim card slot built in so you don't need to pair it with your actual phone.
It requires a 2G Sim Card.
Are PM cards 2G ?
Thanks
Phones
11-03-2019 07:18 PM - edited 11-03-2019 07:19 PM
@jamesgboutilier wrote:Thanks
Does anyone know if there are any Android Smart Watches that "will" work fully (without having to pair your cell phone) on Public Mobile ?
Samsung Gear S using nano SIM card on PM 3G 850 / 1900
https://www.gsmarena.com/samsung_gear_s-6620.php
3G bands | HSDPA 900 / 2100 |
HSDPA 850 / 1900 |
11-03-2019 07:13 PM - edited 11-03-2019 07:28 PM
I've done some quick research and most these standalone Android watches do not have conventional sim cards, instead they have eSims which are built-in. Public Mobile is the cheaper part of Telus and as seen on another thread does not support these special eSims.
The only watch I have confidence in working with Public Mobile is the LG Urbane which I cannot find available in Canada, except for possibly Ebay and other similar sites.
The 1st gen (LG W120L) supports all Public Mobile bands.
The 2nd gen (LG W200A) supports Public Mobile's 3G Bands.
It'd be much simpler to go with a Smart Watch that pairs with Android phones or switch to a mainstream provider which supports eSims for current watches.
Hope this helps.
11-03-2019 06:37 PM
Thanks
11-03-2019 06:14 PM - edited 11-03-2019 06:15 PM
@jamesgboutilier wrote:watches say, regular call features work with any network, BUT, to receive and send texts, or use messenger/facebook, a 2G sim is required.
I wouldn't rely on that information if that's how the manufactuer worded it. There isn't a device in the world that will work with "any network". Further, although some carriers required customers to update to a new sim card to use LTE, sim cards are not fixed to one network type. It's a match between phone/device and network compatiblity that is needed. Either way, there is no 2g network at Public Mobile,. so it's not going to work.
11-03-2019 06:06 PM
11-03-2019 05:43 PM
@Triguy wrote:PM speeds are throttled 3G.
It's the LTE network speeds that get throttled. However, that isn't related to the compatibility with any 2g network.
11-03-2019 05:37 PM
Thanks
Darn... really wanted a Smart Watch.
11-03-2019 05:33 PM
@jamesgboutilier nope, the only network running 2g is Rogers and its not for much longer because it will be phased out. Someone on here had that same watch the other day, search it up in the community and you might find more answers about it
11-03-2019 05:32 PM - edited 11-03-2019 06:02 PM
Rogers has a 2G network but they intend to decommission their 2G network starting December 31, 2020.
