2FA for SIM replacement
Aquosua100
I’m doing a sim change but it’s asking for 2FA that suggest access to the old SIM.
I lost the old SIM and can’t receive 2FA. I will like option to use my email for 2FA instead of being limited to the phone number which I am trying to replace the lost SIM.
any ideas?
1 REPLY 1
@Aquosua100
Did you click on Resend Code or Didn’t Receive Code? There should be an option to have the 2FA Code sent by email.
If not then you need a CS_Agent assistance to help you.
