20GBs plan
Vazir1
Do my rewards and loyalty get transferred when I upgrade my public mobile plan ?
2 REPLIES 2
hairbag1
@Vazir1
just don't ever voluntarily opt for Points. Once you do, you can't come back to old Rewards program. Do the research to see if Points benefit you...but most customers overwhelmingly think Rewards are superior to Points.
NDesai
@Vazir1 Yes, rewards stay as is when you upgrade or downgrade your subscription plans.
