2 Accounts
MrJLlC
Hi. Can I have two phone numbers under one account?
Also, how can I port my number from another company to Public?
2 REPLIES 2
MrJLlC
Thank you
@MrJLlC
no, one account, one number
if you need another number, you need to create another account with another email
and to port number into PM, You want to first confirm your number is eligible to port into PM first here (it is a Koodo site because both Koodo and PM use the same Telus system):
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
Then, make sure your old provider account is still active.  Login to your old provider account and make note of the account number.
Finally, use the app to activate, and request porting during activation process
