$15 PLAN can i send picture message
paul007
pmmobile
@paul007  I neat trick you can try to use if possible: turn on WiFi to get updates for messagings apps etc, then turn on your data to send picture message. If do not have a large amount of data, this can help to keep your data usage lower.
petersonguo
Yes. You are able to send pictures with that plan.
Daps
The $15 plan givess unlimited international texting including picture messaging while you are anywhere in Canada.
geopublic
@paul007  Yes you can. Just make sure you have data turned on and the correct APN setting selected. Ehat type of phone do you have?
