a month ago - last edited a month ago by computergeek541
a month ago
The ZTE box will connect to 4G/LTE on B2, B4, B5 and B12 bands.
a month ago
Not roaming like a Gypsy or a Nomad. 😲
Roaming like using carrier ABC and their signal is weak so the device picks up and uses carrier XYZ signal automatically. And the device remains in the same place.
a month ago
When you say roam, as in where? Canada and US or other countries?
Hi.
My box and specs. So is 4G?
But 4G is for data. I can only makes calls on it. But nevertheless can you roam on a ZTE box?
a month ago
Hey @Yosemite_Sam
I have the ZTE box myself and don't use it for Public Mobile as it's a 3G box. In realty, as long as the box is unlocked, there shouldn't be a problem IF you are on a Can/US plan or have a US calling package. I will not work outside of these two countries.
