Reply
Highlighted
Should I cut the cord...drawbacks?
I'm having a sheeet time with my Bell home phone. They are coming out for a third time tomorrow to try and fix things but I'm not holding out hope. Right now I have no dial tone for two days. They have suggested to let them come in and rewire the whole house for hundreds of $$ and buy all new phones. So I'm considering if they can't find the problem this time to just cut the cord and go straight mobile. That will mean no upstairs/downstairs phones so a little less convient if I forget the cell.   Are there any drawbacks to cutting the cord and just having PM mobile?   Thanks for your input in this decision.  Cheers
Highlighted
Re: Should I cut the cord...drawbacks?
@Lar this applies to calling only*:  I have been mobile-only for my own personal use since 2010, and since 2016 that phone is also my only work phone (changed employers, these guys are mobile-only).
Drawbacks?  I guess:
- like you said, only one device and you have to cart it around with you throughout the home
- exposure to cellular transmissions while on the phone - can mitigate using speakerphone and holding the phone away from you or placing in a nearby table, or use a headset
- if your battery dies you can't make/receive calls
- if there's a service disruption all your eggs are now in one basket
- with PM, you're limited to the 18 countries available via the 400 min LD add-on, so if you need to call elsehwere you'll need calling cards or use a data-based service
- that's about all I can think of but there are probably more.
Pros?:
- one bill (even if you have to crank your plan up a little to compensate--may or may not apply)
- one number for people to reach you at instead of guessing or trying one after the other
- less clutter of phones/base stations around your home
- your phone number follows you wherever you go (this may be a con if you're not a fan of being available all the time)
- home phones are so 20th century!!
I don't think I would go back personally, but everyone's needs are different.
* I still use Shaw for my TV and home inernet, with no plans to cut that cord in the foreseable future but would love to drop the TV part eventually and do all streaming all the time.  😉
Highlighted
Thank you srlawren for the extensive reply.  I feel better hearing about your experience.  The "eggs in one backet" does spook me a bit but there is always wifi calls on an app if PM fails me for awhile. I did look at the $$$ advantage of dropping the landline and upping my PM plan, turns out to be enough to buy a new cell phone each year. Thanks again
Highlighted
I got rid of home phone in 2006 and got freephoneline as i always have internet
It is my homephone since 2008 and i haven't paid a cent since
They let you forward calls simultaneously to multiple numbers also they email any voicemail
I set it also also as sip account on my android native dialer, so i can call 'from home' off of my cell
You have to buy configuration file (around 90 i paid 50 in 2008 it went up, begfore that i was using their free software as i had a computer that was always on anyways) and if you want to use the oldschool headset or lines inn your house a voip box (about 30-50)
Check it out freephoneline.ca
Edit: im assuming you have high speed internet, you'll need more than 6m if you want to use internet fur anything else
Highlighted
hello @Lar
I use a VOIP system in my house. The main reason is for the home security alarm. It needs to be able to connect to the central monitoring station. The VOIP system, if I don't get any incoming or outgoing calls is around $2.80/month. $2.00 for phone number renewal and the rest for E911.
Also, there are cordless phone sets that you can get that have bluetooth enabled. This allows the phone system to connect to your cell phone via bluetooth and you can make and receive calls with your cell phone without having your cell phone on you. All that is required is that the cell phone be near the base station. Here's the one I have:
https://www.vtechphones.com/design-technology/connect-to-cell
The one I have has one base station with voicemail and 3 other handsets that are just the handset with a charging station. The only drawback is that if the handsets are far away from the base station or located through many many walls, it will sometimes lose connection. Other drawbacks is that it is voice calls only. So if you get text messages or social media notifications, the cordless system will not notify you of this. Nor will it be able to send text messages or other tasks besides voice calls.
Other than that, it can handle both landline and cell phone calls independently. You just need to press the appropriate button to make calls from different lines.
Hope that helps.
Highlighted
 @Lar
I've been doing fine with the Telus Home Phone. It uses cellular to get out but you connect a cabled phone to it and it acts like a normal old landline. Connect to a multi-handset cordless set instead and you can have phones around the house again.
$10
Rock & roll.
Remember too that with the old landline that 911 will still work even though you don't pay for any service.
Highlighted
I had a little health incident and fell off the internet for awhile. I wanted to come back and bravo all of you members who spent the time to share your thoughts on the subject. Thank you all.
Cheers
Highlighted
I have dumped my landline in favor of wireless home phone for about 8 years.  Wireless home phone is 100% compatible with cordless phones and the signal can be backfed into the house wiring to operate existing wall jacks if desired.  A lot of people still carry this belief that a landline is the most reliable.  That simply isn't true universally anymore.  The number of people that have cut the cord has left that infrastructure back in the 20th century.  These days with so many people going wireless exclusively, the wireless infrastructure is very reliable and has sufficient resilience to overtake landline as the best choice for home phone.
Highlighted
Good Neighbour / Bon Voisin
I have only one comment about cutting the cord.  SPAM calls.  I am so sick of getting hustled by every spammer out there    i keep my landline for registration online as I find most websites sell the contact info.  I don't blame them for the revenue stream. but I am tired of having someone from Bangladesh interrupting my meals and offering to fix non-existant problems on my computer.
     Just something to think about.
Highlighted
My wireless home phone is a $10 answering machine solution.  I review calls in the evening when I get home.  Spammers are completely welcome to fill my voice mail.  It can take up to 10 calls before it fills up.  So far, I have not received calls at such a prolific rate on a daily basis.
