Screen Protectors
10-23-2019 01:34 AM
Anyone have any advice what is the best screen protector and offers best value?
11-05-2019 12:19 PM
I like the glass screen protectors and you can actually get them from the dollar store and they are the same quality as Walmart or anywhere else 🙂
11-03-2019 01:19 PM - edited 11-03-2019 01:20 PM
@Patrick_R wrote:LG x power 2
I'd recommend getting a tempered glass screen protector like this one from Amazon.ca.
Sure you could get one from Ebay, but the level of quality will probably significantly less than a normally priced one on Amazon.
10-26-2019 03:22 PM
It's just a piece of static-clingy transparent plastic. It has to be cut to the right size, not too thin (weak/useless protection), not too thick (impede touchscreen). Best if one comes "free" with the phone, otherwise the cheapest one is good enough.
10-23-2019 11:21 PM
Thanks
10-23-2019 09:38 AM
Here you go. Canadian source, well priced, plastic and glass option.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.ca%2Fulk%2Fitm%2F332343001731
10-23-2019 08:28 AM
LG x power 2
10-23-2019 02:04 AM - edited 10-23-2019 02:05 AM
Thread moved to the Lounge: not Public Mobile related
I used cheap $1 or $2 tempered glass screen protectors. They aren't as indestructable as the sellers would like you to beleive, but they do provide an extra layer to prevent things coming in contact with the glass screen of the device.
10-23-2019 01:51 AM
@Patrick_R wrote:Anyone have any advice what is the best screen protector and offers best value?
There's very little difference between any. If you pay $20 for one, the store is laughing.
10-23-2019 01:41 AM
What phone are you using?
