Refer a friend credit.
07-26-2020 11:10 PM
Hi. Could anyone recommend some good sites to post reference codes to get the 'refer a friend' credit? Thanks.
08-06-2020 10:37 PM
Condition:
PM refer-a-friend credit is $1 per 30 days as long as your referral stay with PM.
How:
Therefore, after activation support is essential to keep your referee staying with PM. If you don't know who are your referee, you cannot provide before and after activation support. Concentrate on your family and friends instead of leave your refer-a-friend code at someplace and pray for people rushing to activate a PM plan using your refer-a-friend code. If it is that easy, PM has a website and PM does not need us to spread the word as people are rushing to activate PM plan.
07-26-2020 11:13 PM - edited 07-26-2020 11:16 PM
@Alexbear wrote:Hi. Could anyone recommend some good sites to post reference codes to get the 'refer a friend' credit? Thanks.
Well then you'd be a competitor wouldn't you 🙂
Edit: definitely where this thread belongs. I would even go so far as to say that posting those links would in its own way be counter to the T&C's.
