Re: Where is my $1
07-09-2020 05:56 PM
07-10-2020 01:41 AM
If you activated around the same time that you registered your community account then youll see it appear in your rewards about 6 months from now......
07-09-2020 06:03 PM - edited 07-09-2020 06:04 PM
@telemonster you see it in the 30 day cycle after your 2nd anniversary date. Since 12 30 day cycles is only 360 days.
07-09-2020 06:03 PM - edited 07-09-2020 06:03 PM
@telemonster wrote:stop pushing BRAVO - it is a fraud and you keep on pushing that.
What are you talking about? Bravos fraud?
Yes the chatbot is stupid. It should eventually make its way to either private messaging the @CS_Agent. or what's called a ticket.
07-09-2020 06:01 PM
@telemonster use the private message link not the link to SIMon
make sure to check your inbox(top right corner envelope icon) periodically, for a message
07-09-2020 05:57 PM
