Add on problems
Options
11-30-2022 01:03 PM
I keep buying Roaming us data but I can’t get on line
2 REPLIES 2
Options
11-30-2022 04:36 PM
Options
11-30-2022 01:48 PM
@jgoproud which roaming add-on you got?
which network you tried to connect to? Look like T-Mobile is the only one works now. But you can also try AT&T
give us more info
(and don't keep buying if it does not work)
