12-31-2019 01:05 PM - edited 01-05-2022 08:48 AM
Hi, I just want to check if the xiaomi MiA2 is compatible with Public Mobile. I purchased this unit in Asia so from what I see it didn't seem to be compatible but I may be looking at it wrong. Thanks for the advice.
12-31-2019 01:15 PM - edited 12-31-2019 01:17 PM
@MiA2 wrote:Hi, I just want to check if the xiaomi MiA2 is compatible with Public Mobile. I purchased this unit in Asia so from what I see it didn't seem to be compatible but I may be looking at it wrong. Thanks for the advice.
@MiA2 Yes it will work. If it is the Android One phone it supports the following bands:
Bands
4G LTE
B1 (2100), B2 (1900), B3 (1800), B4 (1700/2100 AWS 1), B5 (850), B7 (2600), B8 (900), B20 (800), B38 (TDD 2600), B40 (TDD 2300)
3G
B1 (2100), B2 (1900), B4 (1700/2100 AWS A-F), B5 (850), B8 (900)
12-31-2019 01:15 PM
I'd suggest you find the COMPLETE model name/number of that phone, because according to the link below, there's several variants, some of which will apparently work fully on Public Mobile, and others that won't:
12-31-2019 01:09 PM
This is what Public Mobile phone checker says.
